- Nov 25, 2020
- 832
- 421
Good info from GM
Reference Number: GCUS-9-11766
PF66 (GM #55495105) Oil Filter Shortage and Replacement Parts Effective 8/20/2021
Due to increase in demand in the past 6 months, the PF66 oil filter (GM# 55495105) is currently backordered.
In the immediate interim, GM Engineering has recommended the ACDelco UPF66R as the preferred approved filter.
While not equivalent with the OE filter, considering the potential impact on GM vehicle owner satisfaction, we are allowing the usage of the following aftermarket filters for a limited time until a solution is identified. Additional bulletins will be distributed advising of sufficient PF66 availability and ending the competitive aftermarket filter warranty. We will also continue to warranty the engines (subject to remaining warranty) that receive one of the following aftermarket filters:
- Mighty – M9510
- Valvoline – VO202
- Parts Master – WL610351
- Luber-finer – PH10066
- Champ – PH10066
- Wix – WL10351
- NapaGold – 100351
- PurolatorTech – TL11241
- Purolator – L11424
