Towing smaller Kubota Cab Tractor (4K pounds)
My father and I share a L3560 Cab Tractor we just purchased last week.. it's coming in on Wednesday. We normally pull it with his 2020 Duramax 6.6L. Here's to hoping the mini max can handle it.
I won't be moving it but maybe once a month, so it's not an often thing.
The tractor weighs around 4K per the spec, with the mower on the back around 800 pounds. Trailer is about 3K.
How far are you pulling? I think you will be fine.
I haul a Cat 257D around to different fields, when the 1990 gmc ton dually is hooked to a bigger load for the day.
Farthest I have pulled it, is 7 miles on gravel roads. It is spec'ed at 8545 lbs. Use a H&H 14k tilt bed spec'd at 3540 lbs.
I just load far enough forward to get the rearend to squat down some. At a dead stop takeoff, one has to feather the throttle on gravel. The baby max has plenty of power to traction ratio. I have yet had to put it in 4x4 to takeoff.
I will get a picture next time it's loaded.
Will do! It will be traveling about 50 miles between our houses.
Tractor is here, they delivered it this weekend. Haven't needed to pull it anywhere yet obviously.. when that time comes I'll be getting some pictures and reporting back!
Oh, a picture (ignore the potato quality camera).
