The obd fusion app has it as an option to pick. Still playing with it .Same here. I haven't found a setting for EGT's yet though and would like to see that.
Are you talking about the oil and/or coolant temps? Over 210F is normal for those. Transmission temps should be about 195F. For Exhaust Gas Temps, when regenerating, you should see 1000F+, maybe as high as 1200F (538C to 649C).It’s crazy how hot the engine got during regen. You could smell it in the truck and the temps on the screen proved it . 73c up to 106c at one point.165f to 223f
Ideally, you would want to regen while driving. Regening while stationary uses a lot of fuel and would negatively impact your fuel efficiency. Might as well be going somewhere while the regen system goes thru its cycle. If my regen cycle starts when driving and I know it won't be complete when I reach my destination, I will drive a few extra miles for it to complete before stopping and go thru it's short cool down cycle before shutting it off.
140%? Never heard of that happening before. Mine always kicks on at 100%. It's a good thing you're tracking it. Good idea for the dealer trip to figure out why it's doing that.I only did it because when the DPF hits 140% it requires you to do a forced regen. You're supposed to take it in to the dealer at that point, but I had a road trip the following day and access to scan tools to force it anyways. You never want to have to do it. It's one of the reasons I went down the ODB2 monitoring route.
I just installed the obdlinkMX+ and I’m using the OBDfusion ($20) software because it has an Apple CarPlay app.140%? Never heard of that happening before. Mine always kicks on at 100%. It's a good thing you're tracking it. Good idea for the dealer trip to figure out why it's doing that.
There are 4 EGT pids, only three report temp on mine. One of them is always zero value.The obd fusion app has it as an option to pick. Still playing with it .
