New to forum…21 Sierra, Coolant Control Valve P1098 fixed
HuskerPower1971
I have a 2020 with the LM2. A few months back I started getting P00E0 and P00E2 codes. I wound up replacing the inlet and outlet air sensors located on the cooler on top of the engine. Codes went away for awhile but then came back intermitently. Now the CEL stays on all the time. Yesterday on my way home from work I noticed the temp gauge was higher than normal and the truck was noisy. Sounded like the fans. Second time I have heard this. Did a bit of research last night and discovered there are also sensors located in the cooling hoses. I ordered a couple but not really sure hwere they are located. While doing some more research online otday I ran into these issues with the coolant control valve. Sounds like I am having similar issues although I have not gotten a code calling this out. Since my truck has just over 60k miles should I take this in to the dealership (although I do have some aftermarket items installed) or tackle this myself? Sounds like a striaghtforward procedure, just long. Thanks for any advice!
Welcome.
From what I’ve seen online, the only difference in the newer redesigned CCVs is that they changed the grease to a higher temp formulation that doesn’t break down like the older ones causing premature wear on the gears. I am hoping this fixed for good. Only time will tell.
Cheers,
I just had this issue last week. Car turned on and immediately entered limp mode, CEL came on, and the radiator started going at full speed. Once I got it home and restarted it didn't enter limp mode and the radiator ran normal, but CEL remained on. Dealer said the code was P1098, and according to the service manager, the technician said "we need to replace the CCV, this is happening a lot". Fortunately it was covered under my powertrain warranty, but oddly enough the ECM reflash wasn't and they wanted to charge me an hour of labor (the one time im glad I got suckered into an extended warranty).
I've also been dealing with the extended crank/no start issue since i've owned the truck. After this reflash, the crank is noticeably longer. The service records state they reflashed according to three TSB's, but they couldn't tell me which ones.
Good luck with your truck, it sounds like these valves are a known issue.
