Hi guys....I am planning on installing a single remote oil filter adapter on my 2024 Silverado RST 3.0l Diesel. Derale and Earl's both have several options available. I also want to install a mechanical oil pressure gauge, using the 1/8" port on the remote adapter for the oil pressure. I am having difficulty finding info on what the thread pitch is on the factory spin on filter on the engine block. I will need to install the sandwich adapter for the hose lines. I have come across M16 x 1.5mm and also 13/16". Can someone confirm this? Also, some of the remote filter adapters have 7/8" in/out ORB ports, and others have 1/2" ports. Any recommendations on which to use? I plan to use SS hose with AN fittings. Much appreciated for info!
