2021 LM2 Elevation
- Feb 17, 2021
- 45
- 30
How powerful of an exhaust brake should be expected for a 3.0L engine? I’m guessing it should be noticeable but nothing like a 6.6L duramax.
It should a least as good as the 2.8 minimax in the Colorado.How powerful of an exhaust brake should be expected for a 3.0L engine? I’m guessing it should be noticeable but nothing like a 6.6L duramax.
And what's that one like? Anybody here have any actual experience? Does it have the same towing capacity? If I had to choose between pulling power and MPG or engine braking, I'd go for for the first two. The 2.8 is a wannabe Duramax in a wannabe truck.It should a least as good as the 2.8 minimax in the Colorado.
I owned a 2016 2.8 Colorado for 3 years and pulled the same trailer that I now pull with the 3.0.And what's that one like? Anybody here have any actual experience? Does it have the same towing capacity? If I had to choose between pulling power and MPG or engine braking, I'd go for for the first two. The 2.8 is a wannabe Duramax in a wannabe truck.
I hear you. I'm 6'2" 265 Lbs and 57 years old. I can still fit in my '07 TrailBlazer no problem but just wanted a full size to tow with. The leg and head room in the Sierra is awesome.The only reason I got rid of the Colorado was driver comfort. I stand 6foot 3 inches weight 240 and I am 75 years old with arthritis of the spine, the seat sucks in the Colorado.
Engine braking noise was non existent. The signs your are talking about mean "Jake" brakes, a true engine braking system, not exhaust brakes, that restrict exhaust flow.I hear you. I'm 6'2" 265 Lbs and 57 years old. I can still fit in my '07 TrailBlazer no problem but just wanted a full size to tow with. The leg and head room in the Sierra is awesome.
Engine braking aside, it's still an awesome engine to tow with. My experience with the engine braking on the 3.0 is meh. It would downshift only in cruise and if it was actually going downhill and accelerating on its own. It might also be using the inclinometer to activate it. Although I haven't hit any really heavy grades with it yet, it does seem to prevent accelerating any further. Maybe they've toned down engine braking due to constant noise complaints and signs everywhere to not use it. What was the engine braking noise like in the Colorado?
And are in reference to big trucks not pick ups although straight piped dodges are getting up there in noise lolEngine braking noise was non existent. The signs your are talking about mean "Jake" brakes, a true engine braking system, not exhaust brakes, that restrict exhaust flow.
Personally I hate seeing my engine rev up that high I won’t let it. I’m sure it’s within tolerances I just don’t like it lolI got thrown off by that button since I don't have it, oddly enough. I thought the terrain mode button on my single speed transfer case was the hill descent. No matter, I looked at the 2022 manual and that button is indeed the hill descent mode button. My bad. Still says the engine braking is automatic in tow/haul mode.
Interestingly enough, last weekend, I was hauling some stones using a dump trailer and it did kick it on, quite aggressively, coming down a hill coming to a stop. Like the engine was revving to 4000 RPM. I think it uses the inclinometer along with brake pedal input to determine how much engine braking to apply.
