rbdjr
- Jun 23, 2021
- 181
- 63
I go in on the Nov 5th for the newest re-flash, we will see, mine average happening 1 time every 1000 miles
I haven't heard from anyone so i hope that means a fix. I haven't had a problem since the reflash Oct 26 !!! Im also loving the auto stop reversal lolI go in on the Nov 5th for the newest re-flash, we will see, mine average happening 1 time every 1000 miles
Same with mine.All good fixed 100% But would love to know what was changed? Cranks 1 sec longer now to start only thing I notice
You say you have a CEL, what was the code? For the rest of us who got the update for the crank no start, which was just once but would start on second attempt, the update fixed it. If yours doesn't start at all, then that's another issue. Sounds like you have a totally different problem.My 2021 elevation 1150k power decreased fans running full.. cel on. Tsb update "suppose" to fix it but the no start cranks a lot is cps sensor needs shim hitting timing chain
yesI have only had the ECNS issue twice in over 5000 miles. Wondering if it is worth getting the reflash...
Just happened to me for the second time. I tried 4 times. No dice. I unhooked the negative cable for 30sec. Reconnected and it fired right up. Definitely something electrical.After 10 min in the middle of no where with no help around I disconnected the battery let is sit for 5 min the reconnected and it started???
This has happened twice in the first 2 weeks going back to the dealer as soon as my trip is over.
Anyone have this happen?
As Mooseman said your condition is completely different than what the reflash fixed on our trucks, Everyone so far that I have talked to had an instant restart after the first fail. yours seems to be a completely different condition. Let the dealer figure it out as you stated after your trip.Just happened to me for the second time. I tried 4 times. No dice. I unhooked the negative cable for 30sec. Reconnected and it fired right up. Definitely something electrical.
Agreed. Truck goes in Tuesday morning.As Mooseman said your condition is completely different than what the reflash fixed on our trucks, Everyone so far that I have talked to had an instant restart after the first fail. yours seems to be a completely different condition. Let the dealer figure it out as you stated after your trip.
Has happened to me several times I love this truck but this has me frustrated out going to take it to the dealer tomorrow for the reflash thanks for your info. What was reflash called by any chanceHad it happen 1 time every 1000 miles approx, for the first 11,000 miles, got the reflash, and its been all good since
Did the new updated today let’s see how it goes should be fine going forward fingers crossedpage up the string the doc is listed.
