Oil Analysis by SPEEDiagnostix
HacksawMark
Received my first oil analysis after 40,781 miles. Been meaning to do this sooner but better late than never. First oil change was around 2,000 miles and then every 5-6K miles afterwards. So far, don't' see anything to be concerned about. At the next oil change around 45-46k miles, will switch to Mobil 1 ESP as suggested and also PPE filter. May even consider changing out the oil pan for PPE.
Results look good.
I've been wondering if these labs could start testing for rubber or rubber compounds, nylon or whatever else could be found for the oil pump drive belt.
In the beginning everybody said, nope, not gonna get an engine that has a belt submerged in oil. Absolutely no problems with premature failures that I am aware of.
gm expanded the mileage interval. I haven't heard of any 200k trucks yet, but some should be getting close.
I know there is a video in which Lake Speed Jr mentions oil and the oil pump drive belt but can't seem to locate it at the moment. He said only oil that meets dexosD specifications should be used. I would think that if the belt starts to degrade, it would show up somehow in an oil analysis but not sure what that would look like. I think Blackstone may have a test for that but not sure. I've also read that high fuel dilution is not good for the belt and to try and keep it at or below 2%.
