Oil Pressure 3.0 I6, at idle.
Oil pressure as per the dash gauge idle hot in gear 25psi? Normal? The gauge has 60 at halfway, its normal to below less than a quarter as per the gauge?
Mine shows super low as well.
FYI...
The 3.0 Duamax has a variable-pressure oiling system with a continuously variable-displacement vane oil pump. It enhances efficiency by optimizing oil pressure as a function of engine speed and load. With it, the oil supply is matched to the engine requirements rather than the excessive supply of a conventional, fixed-displacement oil pump.
