I to running 50psi all around, good for miles and tire wear also, ride a bit stiffer I can deal with that. Onstar tells me tire PSI to high LOLI will be the odd man out. I run right up to the max pressure of 50lbs. But there is more likely a pallet of seed or chemicals or wood or salt blocks or pulling a cat mtl on a trailer. Also have a full to the lid crossover toolbox.
But I have replaced the oem 22" tires.
www.intercotire.com
