How the ride compared to stock tires? Does it keep the grip on wet roads? Been looking at these for my truck.Installed 285/50r22 Nitto terra grapplers on a 2021. Like them alot. Been using BF Goodrich KO2's for 25 years. I think I have been converted.
Nitto ridge and terra grapplers are available in 22" tires. My friend has them on his Raptor.Does anyone know if a tire manufacturer makes an AT tire that would fit my truck when the tires need replacing?
Howdy gemarsh,Installed 285/50r22 Nitto terra grapplers on a 2021. Like them alot. Been using BF Goodrich KO2's for 25 years. I think I have been converted.
That’s awesome!Absolutely stock. No issues with them rubbing. Turning or crossing a ditch at an angle.
I guess I should refer to the manufacture’s specifications on sidewall ply strength. The roads I drive have exposed rock here and there. While I’m not rock climbing, I don’t want any sidewall cuts.We don't have rocks, here, so I can't answer that.
Sidewall height isn't much, unlike the old 15" rims of the day, so if that is a concern, I would raise the pressure up to the 80psi air pressure specs on the sidewall, when your going to be in those conditions.
Unless you're rock climbing, then you have the wrong equipment!![]()
It looks like the G2’s are a 10 ply rating allowing the 80 psi max. 10 ply sidewall is what I ran on my last truck for cut durability.I guess I should refer to the manufacture’s specifications on sidewall ply strength. The roads I drive have exposed rock here and there. While I’m not rock climbing, I don’t want any sidewall cuts.
Good point on airing up to protect the tires. Thanks
