- 197
Not for 3.0I , L87 is a gas 6.2 literTechnical Service Bulletin: #20-NA-218 Jan 2021 Revision calls for reflash ECM
Update, New Service Bulletin came out 8/16/21 for the no-start condition, part of it refers back to the damaged exciter wheel and inspection, , and in not damaged to shim the cam sensor. I have no idea if it's a successful repair yet, more to come.
send me your email in a conversationCan you get a copy of that from the dealer, or post the #?
How many days since you had Re-Flash and or miles? I guess it has not happened since reflash softwareI got the latest flash which was released 10/4/21. Dealership I bought the truck at was zero help and had to go to another dealer that knew what i wanted over the phone and got me in a couple days. So, Vermilion Chevrolet in Danville, IL is garbage and Alsop Chevrolet in Attica, IN is very good service for any in my area.
Thanks for the info, keep us updated, I will post a bulletin for others tomorrow, which is my plan, also make an appointment for my truck to get re-flash performed.got it two weeks ago. had the issue every month since I bought the truck. So if it doesn't happen by December I will assume it is fixed. It seems to pause on crank (may be the cooler weather, i dunno) and cranks faster maybe now. All i have seen so far.
I was able to download it and save the file to computer, thanks!Here is a copy of #PIP5823B Intermittent Extended Crank No Start (Oct4,2021) attached below
Let me know if the attachment worked
Thanks rbdjr
Thank you. I gave this to my dealer and told them I want to try this first instead of the shim they already ordered. I go in tomorrowHere is a copy of #PIP5823B Intermittent Extended Crank No Start (Oct4,2021) attached below
Thanks rbdjr
