How many have the Max Towing Package?
noshadowsabre
Just wondering if anyone out there has the Max Towing Package on your truck? What is your payload? Thanks!
Don't have on mine.
Nope, but I don't tow "heavy" either.
Not sure. How do you tell?
The Max Trailering Package includes:
All Features Included With Max Trailering Package:
  • Trailering Package1
  • Increased towing and GCWR
  • Automatic locking rear differential
  • Handling/Trailering2 Suspension Package
  • Enhanced cooling radiator
  • Revised shock tuning
  • Heavier duty rear springs and increased RGAWR
  • 9.76" rear axle
  • 3.42 axle ratio (gas engine), 3.73 axle ratio (diesel engine)
  • Trailer brake controller
Here is an example of the Capacity sticker on the drivers door jamb:
I had max towing package. I tow 8000 5th wheel in ND just fine. If GM can fix the DEF issue. I also have towed 12,000 in dump trailer with ease. Rating on paper 8900 lbs 5th wheel and 13100 lbs bumper.
Here's my capacity sticker
What is the towing capacity of the 2024 GMC Sierra 1500 Denali Duramax?
2024 GMC Sierra 1500 Towing Capacity | Rizza Buick GMC
13,300 pounds
2024 GMC Sierra 1500 Overview
The new GMC Sierra 1500 is rated for an available 4WD diesel towing capacity of up to 13,300 pounds when equipped with the 305-hp 3.0L Duramax Turbo-Diesel engine with a 10-speed Automatic Transmission and 495 lb-ft of torque.
https://www.rizzabuickgmc.com/research/new-gmc-sierra-1500-towing-capacity/#:~:text=2024 GMC Sierra 1500 Overview&text=The new GMC Sierra 1500 is rated for an available,495 lb-ft of torque.
2024 GMC Sierra 1500 Towing Capacity & Cargo Volume
The dealership really pushed this but, I think it is misleading.
You do have to have MAX tow.. there were a few that took it as engine only. Confusing that 5th wheel towing is less then bumper tow but in talking to with GM engineer you can tow behind 5th wheel and they have taken this into account with rating.
Most casual people towing TT's or other recreational equipmentdon't have to worry about max tow weight, it is payload and axle rating that is most important!
Late to the party. I don't have the max towing. Payload capacity is 1600 lb.
13,300 pounds
That's because they don't tell you that you need the MAX Towing package
I have the max tow package. Will tow 12,900. Payload is 1735. Payload is always the limiting factor. I run out of payload 3-4,000lbs under max towing weight.
I have max tow, I think my payload is lower though, a little less than 1600 lbs. Likely because I'm 4x4 In a crew cab config with a fair amount of options. It was only available on SLT, Elevation and SLE trims I believe. I got the highest trimmed SLT available that had it. My towing rating is 12,900. For the newer models (mine is a 24), you get traditional leaf springs rather than the new mono spring they've switched to.
I don't have max tow, but I do need to add a trailer brake controller. There are several plug and play versions available, and even a bluetooth version I'm told. What's the favorite?
