noshadowsabre
- Sep 21, 2024
- 4
- 0
Just wondering if anyone out there has the Max Towing Package on your truck? What is your payload? Thanks!
The Max Trailering Package includes:Not sure. How do you tell?
I had max towing package. I tow 8000 5th wheel in ND just fine. If GM can fix the DEF issue. I also have towed 12,000 in dump trailer with ease. Rating on paper 8900 lbs 5th wheel and 13100 lbs bumper.Just wondering if anyone out there has the Max Towing Package on your truck? What is your payload? Thanks!
That's because they don't tell you that you need the MAX Towing packageWhat is the towing capacity of the 2024 GMC Sierra 1500 Denali Duramax?
13,300 pounds
2024 GMC Sierra 1500 Overview
The new GMC Sierra 1500 is rated for an available 4WD diesel towing capacity of up to 13,300 pounds when equipped with the 305-hp 3.0L Duramax Turbo-Diesel engine with a 10-speed Automatic Transmission and 495 lb-ft of torque.
https://www.rizzabuickgmc.com/research/new-gmc-sierra-1500-towing-capacity/#:~:text=2024 GMC Sierra 1500 Overview&text=The new GMC Sierra 1500 is rated for an available,495 lb-ft of torque.
2024 GMC Sierra 1500 Towing Capacity & Cargo Volume
The dealership really pushed this but, I think it is misleading.
I have the max tow package. Will tow 12,900. Payload is 1735. Payload is always the limiting factor. I run out of payload 3-4,000lbs under max towing weight.Just wondering if anyone out there has the Max Towing Package on your truck? What is your payload? Thanks!
