This nice to know because I plan on running out the old DEF fluid before adding any more.Just the other day, I ran low on DEF and resulted in the "XX miles until 65mph limit".
I refilled it, it took a long time to finally right itself (a couple of drives) but it finally cleared.
I was under the impression that the alarm (speed limitiing) and DEF level are unrelated. There is a separate alarm for DEF level, independent of the speed limiting alarm.
If the DEF low warnings are ignored and the DEF tank becomes empty, the DIC will display messages that describe the action needed and distance until vehicle speed is limited. For the DEF warning light symbol. This came out of my diesel supplement manual for my 3.0 diesel.I was under the impression that the alarm (speed limitiing) and DEF level are unrelated. There is a separate alarm for DEF level, independent of the speed limiting alarm.
If these warnings are ignored and driving continues, maximum speed will be limited further when each of the following counters reaches zero.What were to happen if we continually ignore the warnings and keep running at 65 MPH? I don't drive above that speed since it's our highway speed limit anyway (100 KM/H ~ 62 MPH) and it's more economical to run under that speed.
Mooseman, my experience occurred on my second 3.0. I drove the first one 50,000 miles and because the trade in values were so good, I just traded a 2020 for a new 2021...everything went south on the 2021. Lemon yes, but when it happened to a friend also, and I read through all these posts, it just isn't worth the risk of hanging on to it.Knock on wood, mine's been solid, just turned 30k km. Towing our 6500# TT, it's been great. Sounds like you guys got lemons.
dkboyd,Had the same issue on my 2021 AT4 3.0 IL 6. Engine light and reduced speed warning. Engine light would go on then disappear. Short story is after several reprograms by dealership, no more issues with at but was left with a long starting problem. At 50,000 miles they had to replace my transmission. At 55,000 had three major oil leaks show up. Rear main seal, timing chain cover and oil pan seal. About 70 days of lost time between all the repairs. Filed lemon law suit.
I’m curious to know, did you have issues with your truck pretty much since day 1 or no?Had the same issue on my 2021 AT4 3.0 IL 6. Engine light and reduced speed warning. Engine light would go on then disappear. Short story is after several reprograms by dealership, no more issues with at but was left with a long starting problem. At 50,000 miles they had to replace my transmission. At 55,000 had three major oil leaks show up. Rear main seal, timing chain cover and oil pan seal. About 70 days of lost time between all the repairs. Filed lemon law suit.
Thanks. Should’ve gone withdkboyd,
I just traded mine in for a gasser last year (see above, pure anguish). Should have gone the law suit route. Don't hesitate to get in touch if I can help with my 3.0 experience.
no not day one but after about 6 months or soI’m curious to know, did you have issues with your truck pretty much since day 1 or no?
I am having the same issue. 2020 AT4 since Feb of 2022 28000 miles my truck has been in the shop for 97 day's. They have replaced my entire DEF system, transmission after replacing multiple modules. Crankshaft sensor. Still not fixing the shuttering problem. Now they've had it for another month trying to rewire the 12 volt crankshaft sensor system. I am so done with GMC and I am a life long owner and Chevy legend. They gave me a Colorado for a loner. What a horrible vehicle. I'm embarrassed. GM made this truckWe bought a pre-owned 2020 Silverado with the 3.0 Duramax with 26k miles. Still under factory warranty. Have had the DEF warning about “174 mi until power reduced to 65 mph” pop up three different times but no engine light and DEF is showing 35% to 95% full). Had the dealer look into it when it was in for other problems (bad trans, then crankshaft position sensor) but received no info from dealers (2 different dealers).
My stepson says that he has heard that the problem is with the Blue DEF brand DEF being run in GM engines in the Southwest U.S. (Southern CA, AZ, NM, and western TX). Probably has to do with hot dry climate. The issue seems to be that the Blue DEF brand “calcifies” on the insides of the tank and coats the sensors and clogs the nozzle. He had his DEF system replaced (warranty) and has switched to Autozone and Walmart “house” brand DEF. He says he hasn’t had a problem since. He also said there is some kind of litigation going on about the problem.
Now that my truck is in for the third time for yet more warranty work (codes seem to indicate high pressure fuel system, and internal communications network), hopefully this GMC dealer (we’re stranded in Prescott, AZ) will also check into the DEF problem.
