MyDefectiveGMC
- Sep 9, 2022
- 3
- 0
Sounds like the same thing mine is doing. Let us know what happens.Sorry, don’t remember the brand (truck came with them).
Update:
Headed home with running boards disconnected. Pulling TT, 55 mph, 7th gear, 1800 rpm, cruise control, tow-haul mode, slight grade on interstate, registering about 14 mpg (truck isn’t working too hard). Slight drop in power and mileage (12 mpg) for 10-15 seconds, than trans slams into 6th (as indicated by 300 rpm increase), then immediately shifts smoothly back into 7th (300 rpm decrease). Stopped and checked OBD codes. Only one (P0336 Crankshaft Position Sensor Performance). Continued on towards home. Same thing happened two more times. It then happend a fourth time with all kinds of warnings on the DIC (“Service emissions”, “174 miles before 65 mph max”, “Limiting power to 40 mph”, “Power steering assist deactivated”, the engine stopped, “Put in neutral to restart engine” (interesting since I was now coasting at 30 mph with flashers on, trying to make an unpowered right lane change in front of several 18-wheelers in order to get onto the shoulder, and would have to apply the brake in order to restart). I put it in neutral, hit the start button, all the instrument lights and information displays turned off. Putting it in neutral did help increase the coasting distance. After I coasted safely off the road, I checked the codes.
P0336 CS pos sensor perf
P0087 Fuel Rail Low Pressure
P0700 Trans Control Module
P228A-B Fuel pressure regulators 1-2 force engine shutdown
U0073 CAN bus Communication
U0074 Ctrl mod comm bus B off
U0076 Ctrl mod comm bus D off
U0129 lost comm with brake system control module
U029D-E lost comm with NOx sensor 1-2 module
U02A1 (no definition in reader)
U0100 lost comm with ECM
Was able to continue home. Didn’t use cruise control, used 5th and 6th gears. Took it to dealer. They had GM field tech look into it. Based on others vehicle problems and solutions, they are going to replace the engine wiring harness. Should be ready in a week. We’ll see what happens.
