2021 LM2 Elevation
- Feb 17, 2021
- 45
- 30
Interesting. Another interesting thing I’ve learned… No magnet on the oil drain plug…
Just got done with another long road trip pulling the 7300 # camper. Averaged burning a quart every 500 miles. Went 3000 miles pulling camper and used 6 quarts. Truck ran perfect other that drinking oil. On another 2500 mile trip without towing, it didn't seem to consume any oil.
5 yr 100k miles on the diesels. Mine is still within 3 yr 36kWhat is the US powertrain warranty? Ours is 5 years/160K km on diesels.
It's at the dealer now. They are aware of the oil consumption and I have info indicating high oil consumption will burnout the glow plugs. Seems like my exact problem and hopefully gets fixed. We'll see what they say.@St8fan , that is definitely not normal. I would bring this up with the dealer. 6 qts is not normal, towing or not. I've been towing a bunch and used at most 1/2 qt. If they say it's normal, ask them to show you in the service manual where it says that. Call out their BS!
That is jiving with our warranty.5 yr 100k miles on the diesels. Mine is still within 3 yr 36k
Do you have a link or a copy of that info? Seems like it shouldn't affect the plugs but if it does... certainly something to keep an eye on. Maybe oil just coats them and burns them out?I have info indicating high oil consumption will burnout the glow plugs.
It sounds like oil coats and burns out plugs. Plugs 2 and 3 seem to be the main victims. Just got the truck back and they ordered the cam cover. No eta on when it will be available. I will update once the work is complete. All of this would covered under the powertrain warranty if i was beyond the 3 yr /36 mo according the the warranty book that came with the truck.That is jiving with our warranty.
@Marvin24 , you should still be able to bring it in on warranty. It's getting close so I wouldn't waste any time.
Bought a pre-owned 2022 Silverado LTZ Z-71 with 3.0 Duramax with 26k miles. Drove it for two weeks then trans went out (2 1/2 months to get it and trailer light control module replaced under warranty).
The day we got it back, we left on a 3000 mile trip pulling 5700# travel trailer. Went through 1 qt of oil every 800 miles. After we got back, had dealer start a 2k mile oil consumption test.
Midway through the test, had the crankshaft position sensor go bad (a week and a half for warranty repair).
Had dealer complete oil test today. No oil was burned over the last 2000 miles, but we weren’t pulling the trailer at all. Had the dealer start another oil consumption test today since we will be towing our trailer about 1000 miles over the next two weeks. Will be interesting to see what happens.
Maybe get them to look into your cam covers, it’s apparently an issue on some trucks and why some lose none and some lose lots of oil:Bought a pre-owned 2022 Silverado LTZ Z-71 with 3.0 Duramax with 26k miles. Drove it for two weeks then trans went out (2 1/2 months to get it and trailer light control module replaced under warranty).
				Don't want to be a debbie downer, but you have to have the worst luck after reading your posts!.Update on oil consumption test.
Took off on week and a half trip pulling 5700 lb. travel trailer (Riverside, CA to Phoenix, AZ, Woods Canyon Lake near Forest Lakes, AZ, Prescott Valley, AZ, then back to Riverside). 50 miles into trip, along I-10 in Cabazon, CA, the RR trailer tire blew. Replaced with spare and moved on. 20 miles farther, ran into huge dust storm near Palm Springs, CA. Traffic slowed to 25 mph, hazard lights flashing, 200 ft visibility. LF trailer tire blew. No way was I going to stop on the side of the freeway under those conditions, so I limped it 2 miles down the freeway and got off at an exit and spent the night in Costco parking lot (got permission from manager so security was aware. Next morning got 4 new trailer tires at America’s Tire across the street from Costco. Rest of trip to Phoenix was uneventful.
On the way to Woods Canyon, while pulling a grade at 2100 rpm in manual 7th gear, doing about 55 mph in cruise control, the engine cut out for a half second (same symptom as the CS position sensor problem, but no check engine light ... yet). A couple miles further, same scenario, but this time the shutdown was complete, accompanied with check engine light and “Service Emissions System”, and “174 miles until 65 mph max” on the DIC. DEF level was 1 tick below full. Broke out my code reader and got the following codes:
P0216 Inject timing ctrl circ
P0087 Fuel rail low pressure P020A-F Cyl 1-6 inj timing
P0336 Crankshaft pos sensor performance
P034B CS pos sen direction incorrect
P0700 Trans ctrl module
P228A-B Fuel Pres reg 1-2 ctrl force eng shutdown
U0073 CAN bus communication
U0074 Ctrl mod comm bus B off
U0076 Ctrl mod comm bus D off
U0100 lost comm w/ ECM
Initially the truck wouldn’t re-start (cranked like crazy, but no dice). Manually turned engine off and let it sit 10 or 15 seconds so it could collect its thoughts, tried starting it again and “It’s alive!” Continuing on up to Woods Canyon, I experimented with different things and found that if I kept the rpm above 2500 while using a gear or two lower than normal, it seemed to pull ok without problems. We stopped in Payson, AZ for some groceries. While gently accelerating out of signals, it seemed like it was missing and had very little power until it got over 2000 rpm, then it took off.
Called the GMC dealer in Prescott and made an appointment for the day we were going to leave and go visit family in Prescott, AZ. So, here we are parked next to my son’s house mooching power, truck is at the dealer (hopefully we’ll hear something tomorrow), driving a SUV on GM’s nickel.
More to follow as new info becomes available.
